Renovation of a very damaged sofa
can you tell me and advise me how to renovate a damaged and even hanging leather sofa (see photo)?
can you tell me what else happens so that the leather doesn't crack when you sit on it?
how can you remove a ballpoint pen that has not left with 70Âc alcohol?
thank you for all your advice.
To repair snags, you need the repair paste for the leather parts we will provide you, free of charge. We will explain how to make these repairs.
For dry leather, you must make several applications of nourishing oil to restore the leather's tensile strength.
If you recolour your living room and we think you have no choice, the pen traces will disappear by recolouring, otherwise you have in our products the remover cleaner or the gum'ink.
sofolk
Which repair paste should I buy and which piece of leather will you provide me with?
I would like to place an order.
What oil should I buy because I don't know what oil I have?
As far as recoloring is concerned, I have 3 sofas with 6 seats in total, I think it will be too much work to recolor everything, if the sylo can leave it will fix me?
Thank you for your advice (very good site!)
Below are the links for paste, oil (effective on all leathers) and detergent, we offer you the gum'ink. Try first with the detachant cleaner (repeat 6, 7 times if necessary) and then with the ink gum. If the stains do not disappear (too much incrusted), they will be attenuated, in this case you will have to recolour but you will have fewer layers to pass to cover the ink stains.
- Leather repair paste
- Leather nourishing oil
- leather cleaner
Sofolk
Pulverizer included?
Dying a natuzzi sofa
Par Bill, le 15/01/2024
Par MAX B, le 17/08/2020
Change of colour of sofa
Par Kd, le 14/10/2019
Stained leather renovation
Par Alain, le 09/10/2019
Renovate sofa
Par François, le 30/09/2019
Par JEAN-LUC38, le 01/09/2019
Sticky leather sofa
Par Freddy, le 24/08/2019
Par CAROLINE62, le 20/08/2019
Par Ana, le 16/08/2019
