Leatherette sofa repair
I would like to know how, and with which products, to repair this type of problem on a leatherette sofa.
(See the photos)
Thank you in advance
Regards
(See the photos)
Regards
Not all leatherettes are of the same quality. The surface of your sofa is peeling slightly. There is no real "missing material", so there is no need to get our leatherette repairer.
We advise you to lightly sand the area concerned to remove whatever is no longer holding. Then degrease the surface with methylated spirits or acetone. Finally, recolour over the top and protect with the clear varnish. Our leatherette paint, once applied, will help to consolidate your material.
Hello
I am contacting you for a little information; I wanted to know how to repair my white leatherette sofa. It has torn at the back, at the seam; I would like your advice please, I need help. Kind regards
100 % made in France, in Bordeaux, since 1989
Delivery countries and shipping costsA SOFOLK technician helps you choose the right products and shade
