Stressless tearing
· 1 replies · 2090 views
I have 2 Stressless armchairs, whose model I do not know but which are more than fifteen years old, and one of them (the wider one) is tearing on the seat along a seam. What should I do, please, to stop this as quickly as possible? Thank you in advance
    Repair the hole by inserting a small piece of leather into it, then use the paste to glue this piece against your leather, flesh side facing you. If necessary, the hole sometimes has to be enlarged. The leather and the paste are available in the tear kit.
    After this step the hole is filled, and it remains to recolour and varnish again. For this, choose a touch-up kit. As for the colour, I recommend that you send us a small cutting so that we can make a copy. A square of at least 12 mm x 12 mm is required. So, when choosing your colour, select the option "I will send a sample" and follow the procedure indicated.
    For more details and information our advisers are available on 05-57-34-69-72.
    Thank you for your trust, the SOFOLK support team.
