Renovating a Chesterfield 3628
· 1 replies · 3474 views
I have bought a Chesterfield sofa but I do not know whether it can be repaired with your products.
If so, how should I go about it and with which products?
Thank you
    Your sofa can be repaired. Here is what you need:
    -240-grit sandpaper x3. To remove as many small bumps as possible and to smooth the repair paste.
    -Cleaner/degreaser x1. For a sound surface to which the products will adhere. It can then be used for everyday cleaning.
    -Flexible clear glue CicaCuir x1. To reinforce the bottom of the cracks.
    -Repair paste RépaCuir x3. To fill the cracks.
    -Pigment Leather Paint, 1 litre. To hide the repairs under a layer of plain, covering colour. Apply with a roller and brush. Choose a colour lighter than the dye.
    -Dye, 2 aerosols. To artificially create shading with an authentic look.
    -Wax, 500 ml. To protect your leather after the work. To be used for quarterly maintenance.
    -Oil, 200 ml. To rehydrate your leather. To be used for annual maintenance.
    Our products are supplied with detailed instructions. Should you need to, our team of advisers is also available to answer you directly by telephone.
