Cracked and discoloured leather
· 1 replies · 456 views
what do you recommend to repair a discoloured boat bench with cracked and sometimes even worn leather?
Thank you in advance
    You will need to feed your leather first. Use nourishing oil for this purpose. One or two applications spaced about ten days apart.
    Then, fill in your cracks, cracks and crevices with the leather repair paste. Recolour with the leather pigment recolourant that suits you best. Protect your leather renovation with the silky varnish.
    It should be noted that for a leather regularly confronted with a high humidity level, it is desirable to apply a coat of leather waterproofing after the varnish.
    Renovation boat, leatherette upholstery
