Repainting a headboard
· 1 replies · 1371 views
I would like to repaint the headboard and the white leatherette sides. I would like to repaint everything beige; is that possible? If so, what quantity of paint should I get? Thank you.
Kind regards,
S.E
    Yes, it is perfectly possible to repaint the headboard and the white leatherette sides beige. To do so, here are the recommended steps:
    1. Sanding: Before starting to paint, make sure you lightly sand the surface to create optimum adhesion.
    2. Degreasing: Then degrease the surface to remove any trace of dirt, grease or products that could impair the adhesion of the paint (acetone).
    3. Painting: Apply the beige paint in several thin coats rather than one thick coat. This will allow more even drying and a better result. In general, a quantity of 500 mL should be sufficient.
    4. Varnishing: Once the paint is dry, we recommend varnishing the project. The varnish will protect the paint and ensure greater durability over time.
      We remain at your disposal.
      SOFOLK support
