Leather car seat, Mégane 2 CC
· 1 replies · 3250 views
I would like to know whether it is possible to repair my seat with one of your products, as the hole is quite large and spans almost the whole width of the seat. Thank you
  • Leather car seat, Mégane 2 CC - 1
  • Leather car seat, Mégane 2 CC - 2
    The photo was taken from a little too far away, which does not allow us to assess the situation properly.
    If it is the seam that has given way, the best solution is to re-sew it. No gluing solution gives such a strong and lasting result.
    If it has torn along the seam, it is different, and the repair will only be possible if a large piece of leather can be inserted and glued under the seat. In this case it is precisely the seams that can prevent the repair. It depends on whether or not the seam is caught in the foam.
    So your seat can be repaired if you can slide a piece of leather under the seat to use as a backing on which to glue the torn pieces.
    In that case, after gluing with the repair paste, you will use this paste again to fill the gaps left by these operations.
    You then need to recolour to hide the repairs. And finally, you need to varnish to protect the colour.
    If this was not clear enough, our customer service team will answer your questions directly by telephone on 05-57-34-69-72.
