Damaged wallet
My wallet is damaged. I drove over it while it was on gravel.
There are no tyre marks, only gravel punctures and scuffs.
Can you help me repair it?
I should say that it is patent leather.
Thank you
Thank you
It is possible to work on your wallet and make this minor damage disappear.
You will need our small renovation kit. It contains everything necessary: abrasive paper, repair paste, leather paint and varnish.
1 - Sand the surface lightly without pressing hard, simply to break the original varnish.
2 - Clean quickly with acetone
3 - Apply the repair paste very locally to fill the small holes, leave to dry and repeat if needed, as the paste shrinks a little as it dries.
4 - Sand again very lightly, to get a smooth surface back.
5 - Recolour with the black leather paint.
6 - Apply 2 coats of varnish
Thank you
Will the repair paste accept the movements that the wallet will undergo? I mean in a pocket and so on, it will not crack?
The repair paste is designed to move with the leather. Moreover, a wallet is more subject to rubbing than to twisting. The varnish protects very well against rubbing.
Here is the kit you need; it is the smallest in our range, and it contains:
-abrasive paper
-repair paste
-leather paint
-varnish
100 % made in France, in Bordeaux, since 1989
Delivery countries and shipping costsA SOFOLK technician helps you choose the right products and shade
