Light beige sofa seat discoloration
· 1 replies · 2494 views
Is there a solution to improve the colorful appearance of the bases of my light beige sofa?
And there's also a trace of a ballpoint pencil?
Thank you for your answer
    The discoloration of your sofa has two causes, the first is exposure to light or sunlight, the color changes very slowly. The second cause is the repetitive friction that initially wears out the protective varnish and then attacks the dye layers. We think you're in the second case. All you have to do is reapply the dye, in our company it is called Pigment Recolourant
    For pen traces, if you need to recolour, the Cleaner Stripper will reduce them strongly and they will disappear completely after recolouring. we also have the Gom'encre but which is only effective if the ink is not indelible.
