Here is the PROCEDURE / TUTORIAL for repairing this snag on your high-end leather sofa.
1- LIGHTLY SAND the surface to be treated with our ABRASIVE PAPER
2 - RUB briefly with acetone, to remove dust and degrease the area.
3 - COAT the bottom of the cavity with our REPACUIR LEATHER REPAIR PASTE. The paste shrinks a little as it dries; repeat the operation to get it perfectly level, then sand off the excess.
4 - MAKE A CUSTOM STAMP using our GRAIN REPRODUCTION PASTE, to restore the texture.
5 - STAMP the coated area once, after applying a fresh thin layer of repair paste.
6 - RECOLOUR: choose the colour "I provide a sample" to obtain a custom-made PIGMENT LEATHER PAINT . Apply the leather paint with a small roller, a sponge or a brush, available in the ACCESSORIES section.
7 - VARNISH AND/OR WAX to protect your work and your furniture from scratches and spills. Our PROTECTIVE WAX gives a very pleasant feel, but needs to be renewed a little more often than our PROTECTIVE VARNISH . The choice is yours. It is possible to have double protection by applying the varnish, then the wax.
8 - HYDRATE your leathers with our NOURISHING OIL "neatsfoot".
