Woven task
· 3 replies · 1926 views
Hello. I'm currently re-coloring the leather of my car seats and I accidentally stained the central fabric of the seat. With what can I detach the seat? Thank you.
    With our detachant cleaner there is no problem. For other products I can only advise you to be careful. The product is water-based, maybe a little soapy water, be sure to wipe with a microfiber cloth to remove the re-colorant.
    I'll try with a standard stain remover if it doesn't work I'll order the stain remover. Thank you
  3. Reply
    Hello. Problems solved with stain remover for the laundry. Thank you. Thank you.
