There are two ways to renovate a nubuck sofa or armchair:
- keep the velvety and tinted appearance by spraying a dye. This type of renovation is only done when the living room is not too smooth and especially not stained.
- transform the nubuck into smooth leather, then re-colour it. Basically, nubuck is a smooth sanded leather. By transforming it into smooth leather, it is restored to its pre-sanding appearance. This type of renovation makes it possible to rebuild a stained and smoothed nubuck living room.
RE-COLOURING OF A NUBUCK LIVING ROOM
- With a sandpaper (coarse grains), restore velvety to smoothed areas
- Clean the head sites first with Sebum Cleanser, several times over several days, unless there is no halo(s), in which case one time is sufficient.
- Spray the Stain Remover Cleaner on the seats, armrests and backrests. Wait a few tens of seconds and wipe with a microfibre cloth. On stains, spray with foam (option available on the sprayer). Brush, wait 3 minutes and wipe with a microfiber cloth. Repeat the operation if necessary.
- Wait until the leather is dry and spray the stain with a spray gun (nozzle 0.8 or 1 mm), in two or three coats.
- Apply a good coat of Fixative with a spray gun to prevent the dye from disgorging.
- In the end, apply the Waterproofing agent with a damp sponge.
RENOVATION OF A NUBUCK LIVING ROOM with Smooth leather transformation.
- Clean seats, armrests and backrests with Stain Remover Cleaner.
- Repair cracks, fissures, etc. with the repair paste if necessary. (Operation on nubuck)
- Apply two coats of Colourless Filler Resin with the foam roller.
- Wait 2 hours before applying the Pigment Colouring Agent with the same roller (water cleaning)
- Wait 48 hours and apply a good layer of Nourishing Oil.
- Let the oil penetrate the leather, and apply a coat of Silk Varnish
We invite you to ask your questions by clicking on the'Answer' button. You can also enrich our explanations with your different experiences and also submit your renovation photos.
Par SOFOLK, le 26/07/2017 |
Par SOFOLK, le 06/01/2015 |
Par SOFOLK, le 30/12/2014 |
Bottle size question
Par Goyova, le 20/09/2020 |
Dying dining room chairs
Par TB, le 15/07/2020 |
Can we mix the colours?
Par BT, le 30/09/2019 |
Information sofa skaï flaked
Par JULIEN34, le 19/08/2019 |
Par Thomas, le 02/04/2019 |
Staining a trace alcantra
Par Meisbrm, le 30/11/2018 |
Par Dupré, le 15/10/2018 |
