Doubt one on a leather or imitation leather sofa
as agreed during our telephone interview I am sending you pictures of my sofa.
I have a doubt about the material of my sofa it was sold to me like a leather sofa but I think it is imitation.
What type of product should I use to change its appearance?
Here are my phone numbers 06 14 14 65 77 92
We do not see well at all on the pictures, the best is to send us a lamella of material taken in a cushion, cut out ,ready seams 5 mm wide and 2 or 3 cm long, we suffice.
It's too difficult to do. We should dehousser the sofa.
I sent you another picture from the inside at the seams taken with another camera.
Is this more visible to you?
The underside looks like weaving from the photo, so it's imitation leather, and it also flakes. So there's a good chance it's fake. Leatherette is a fabric covered with a plastic film. There remains the fire test, approach a flame above (make on a hidden part) the leatherette or imitation melts, not the leather.
yes indeed it melts, could you now tell me if I will have an optimal result given the state of the sofa, and if so what type of product should I use.
Thank you. Thank you.
With the products we will deliver to you you will have an optimal result but the application with the roller should be done in cross with an application time between coats of at least 5/6 hours ,with a minimum of 3 coats at the flakes places. In fact, you will apply a hairspray to block the degradation of the initial color. This solvent-based hairspray should be rolled well to avoid dissolving the previous coat. If you can apply it with a spray gun, it is easier. This product does not require a protective varnish but we guarantee its resistance to friction.
So we're going to do it with a gun, could you please prepare my order for me?
We are preparing the order for you, which we will send you by email tonight, we need to add on the site products that are only available for professionals.
You need 2.5 litres of White Colouring Hairspray. With this product you will be delivered the necessary amount of Degreaser and scratch repair.
could you tell me how to proceed with my order, because I didn't receive your email.
We have provided you with a link in the previous answer that allows you to place the order. You will find it below. You order 2.5 litres, we will deliver 3 litres.
https://www.renovation-du-cuir.fr/en-gb/furnishing/N.C./fixatif-colorant-blanc--fixatifcolorb.html
I have the same problem as this person I have doubts as to whether it is leather or semi-leather or other not easy to really define what material it is exactly
In case of doubt, we will deliver you a leather recolouring compatible with both materials. Please specify this in the comments of the order.
What accessories are needed to restore the caneper I need?
How can I be sure of the right color knowing that I can't cut a slice of material?
Just order the pigment recolorant, we'll put the rest in.
Under the sofa you can degravel the clean cloth over a few centimetres and around a foot cut a slat.
I choose which item in which section to place my order?
click on the following link to re-colour compatible imitation leather.
Go to the furniture tab, select leather lounge and then recolour and recolour all colours for leather lounge.
Par SOFOLK, le 26/07/2017
Par SOFOLK, le 06/01/2015
Par SOFOLK, le 30/12/2014
Bottle size question
Par Goyova, le 20/09/2020
Dying dining room chairs
Par TB, le 15/07/2020
Can we mix the colours?
Par BT, le 30/09/2019
Information sofa skaï flaked
Par JULIEN34, le 19/08/2019
Par Thomas, le 02/04/2019
Staining a trace alcantra
Par Meisbrm, le 30/11/2018
Par Dupré, le 15/10/2018
