I have finally decided to make my seats and after 2 coats of dye the color does not match. It is whiter than the original.
Sorry for the late answer but I couldn't find the time. For the shade it looks a little whiter but finally I'll deal with it. So I'm going to re-dye everything (seats and door panels). As you advised me, I didn't varnish and so my seat is all sticky. Is this normal?
Everything that has been dyed. So I remove everything with water and a sponge but it's long. I hope the next colouring will hold.
Your problem comes from a bad stripping, your recolourant does not penetrate the leather, you have to strip and not clean with water then sand the leather to open the pores which allows the recolourant to go down into the leather for a good fixing. The preparation work is longer than the recolouring but very important, you do not apply waxing but the same product as the one that originally coloured your leather.
You wanted a picture to compare colors. There she is. There is a big difference.
Hello and thank you,
I applied three layers to my seat. Do you think I should remove everything or just apply a last coat to the right color?
And so I think that my quantity of product will be insufficient to do everything. If this is the case and I have a new order to place how to do for the shade. I take the same white again and use the dye you send me?
Thank you for your answer
Thierry
Couleur sièges bmw
Par Maxime, le 21/04/2024 |
Par Max, le 17/04/2024 |
Bmw z4 perlgrau
Par Teme, le 16/04/2024 |
Par Massimo, le 10/04/2024 |
Rinnovo volante pelle jaguar
Par Maxime, le 08/04/2024 |
Color change on bmw seats
Par Samppa, le 26/03/2024 |
Par Abbi, le 01/10/2023 |
