Hello Sir
As promised I leave you the photo of the colored seat, you can see that the color has nothing to see it is darker and the color not really close have is not far but not quite that
Hello Sir
Ok thank you but a color you have to apply on the original leather and especially let it dry! 1 cm is enough to see if the color is close or not, it would be better to make several samples 1 ml is enough to make a test on leather once dry of course!
if people ask for a different color that is impossible to see ! if the color is in conformity, a color chart at a body shop with a spectrometer has the excat color of which I do not understand why for leather we can not find the same color even partial to recolor the leather
it is necessary to do tests if not impossible to find the color excate!
thank you for your answer and help
Ps: still not received the oil to feed the leather is normal?
Hello Sir
Thanks for oil! I recently received it, I put it on my leather seats it is super long to penetrate the leather several hours it takes very little, the best and uses a foam pad of bodywork the oil is better to restitiuer than a sponge that drinks a lot and therefore loss, but it seems to me that the leather is a little softened because it was very dry!
Hello after putting the oil 2 layers 2 nights to let the oil penetrate, shamefully I didn't really feel that it softened the leather but it's not bad, I find that the beef marrow or cream base and much better flexibility level!
it is true in full sun the leather is more flexible but in the morning when touching the leather it is as before it distorts the data
Indians in America use the brains of the animal kills, mix with water I know these horrible but that's how it softens the leather, the more the elbow oil of course, that's for the little story!
I'm waiting for the re-colorant and the product you told me you were going to use as a leather cleaner and the spray paint can waved at me once you've thanked him.
Read our instructions for use and you will see that it takes at least 3 applications of one month to reattach the fibres with the oil, this application is done by massaging the leather, otherwise you have a leather softener in our range.
The SOFOLk team
Hello Sir
Yes I have read the instructions for use it says to pass 1 coat wait 10 hours then wipe, then a second coat let the leather hang between for 10 hours then wipe, which I did! But leather wood very little oil except in some places!
It's okay, it's better that way than nothing at all.
on the other hand have a plastic paint for my Audi a4 whose reference is black soul soul even water it doesn't matter!
kind regards
Hello Marc
I would like to know when I receive the colours for my fittings I need today for everything reassembled, I left you the cover on the fuse side grey green, a black soul washer, is the cover under the handle
Let me know when it's over. Thank you.
In the name of Mr. riu frédéric
Hello Marc
Okay, perfect! For the plastic dashboard the liquid is perfect, for the wrists a bomb is better, a small 200ml bomb is enough, I don't know if you do?
for black soul in liquid is perfect!
by thanking you
Hello Marc
I received the fillings, while I'm waiting for the products! Don't we understand that? If you have made the colours and they are identical you can send them to me that's what I need to reassemble my trimmings!
I don't know how much I'm gonna have to wait months now!
I'm in a hurry after I wouldn't have time, temperatures are dropping.
I saw in the recoloration section a before/after picture of a black seat originally recolored in blue!
So I wanted to know how many applications are needed to get this result knowing I only have the square of the driver's seat, the passenger seat and a strip of the backrest of the bench that will be repaired with black leather!
Is the recolouring kit sufficient for the parts mentioned?
Thank you.
Color change on bmw seats
Par Samppa, le 26/03/2024 |
Par Abbi, le 01/10/2023 |
Change to lighter colour
Par Paul, le 26/09/2023 |
Seat repair ?
Par Sto, le 10/08/2023 |
Taupe mer
Par Azem, le 26/06/2023 |
Par Simenk, le 03/05/2023 |
Saab 07 anniversary seat repair
Par Paul, le 30/03/2023 |
Bmw pergament
Par Luca, le 31/01/2023 |
