Leatherette use to fill a hole
Is it possible to use a very thin piece of leatherette to put under the leather in the case of a hole before putting repair paste or should only a piece of leather or non-woven be used.
In your case it is better to put a piece of leather, because the hole is too big, otherwise it is enough to glue the piece of leatherette with neoprene because the repair paste for leather does not stick well the leatherette on the leather but it fills the cavity and clings on the leatherette We can send you a piece of leather.
Sofolk
Thank you for your answer.
Would it be possible to attach a small leather sample to my order
NÂ BDC201401/2105.
Thank you. Thank you.
No problem, we'll do the necessary.
Thank you very much.
Before I start repairing my seats, I need more information.
In your instructions, nourishing oil comes into phase 5.
In my case, wouldn't it be better to put the oil first because the seats are very dry before putting the repair paste because I read that afterwards, the oil wouldn't penetrate when there was paste.
If this is the case, would the repair order be:
clean and sand
Oil to soften the leather (let dry)
Repair holes and cracks
Recolor with pigment recolorant
and protect with varnish
Thank you for your help before making mistakes.
Sincerely,
Yes, it's exactly like that.
Couleur sièges bmw
Par Maxime, le 21/04/2024
Par Allicerrot, le 21/04/2024
Par Max, le 17/04/2024
Bmw z4 perlgrau
Par Teme, le 16/04/2024
Par Massimo, le 10/04/2024
Rinnovo volante pelle jaguar
Par Maxime, le 08/04/2024
Color change on bmw seats
Par Samppa, le 26/03/2024
Par Abbi, le 01/10/2023
